Re: NEW INFORMATION!!
Ron Brown /
Paul,
Relax, it has been scientifically proven that freeking out about ped problems significantly impairs your ability to operate and enjoy your ped. : )
It sounds like your smaller jet improved things somewhat, so going in the opposite direction would most likely make it worse.
Have you tried running without the air box and/or filter to see if you still 4 stroke. Often, as you increase rpm and the need for air, the existing set up will restrict the air flow enough to cause the mixture to richen up.
Try this and post results.
Ron
  14mm bing carbTopic by: paul paul 11/12/01 05:32PM
  Re: 14mm bing carbRe: Ron Brown Ron Brown 11/13/01 10:24AM
  Re: Slide NeedleRe: Brian Brian 11/13/01 11:48AM
  Re: ron, brian???Re: paul paul 11/13/01 04:38PM
  Re: ron, brian???Re: Ron Brown Ron Brown 11/13/01 08:01PM
  Re: ron, brian???Re: Brian Brian 11/13/01 09:11PM
  Re: bing carbRe: Charles Charles 11/13/01 05:56PM
  Re: NEW INFORMATION!!Re: paul paul 11/18/01 08:38PM
  Re: NEW INFORMATION!!Re: Ron Brown Ron Brown 11/19/01 12:10PM
  Re: RON, BRIAN, IVAN, NEED HELPRe: paul paul 11/18/01 11:01PM
