Re: ron, brian???
Ron Brown /
Paul,
I wish I could give you a simple answer, but I can't.
If it is four stroking at high speed, you most likely do need a smaller jet. I notice you seem unsure of this, if it starts four stoking, you get an immediate loss of power and a very distinct change in engine note.
I'll describe your other problem as hesitation off idle. Does this happen if you roll on the throttle more slowly? Do you have an idle mixture adjustment and if so, have you tried turning it in or out to see if that makes a difference? Does moving the needle from all the way up to all the way down make a difference? If so, what?
Sorry I can't be more specific but these are the tests I would run if I had the problem.
Btw, have you made sure your timing is right and your carb has no crud in any of it's passageways?
Ron
  14mm bing carbTopic by: paul paul 11/12/01 05:32PM
  Re: 14mm bing carbRe: Ron Brown Ron Brown 11/13/01 10:24AM
  Re: Slide NeedleRe: Brian Brian 11/13/01 11:48AM
  Re: ron, brian???Re: paul paul 11/13/01 04:38PM
  Re: ron, brian???Re: Ron Brown Ron Brown 11/13/01 08:01PM
  Re: ron, brian???Re: Brian Brian 11/13/01 09:11PM
  Re: bing carbRe: Charles Charles 11/13/01 05:56PM
  Re: NEW INFORMATION!!Re: paul paul 11/18/01 08:38PM
  Re: NEW INFORMATION!!Re: Ron Brown Ron Brown 11/19/01 12:10PM
  Re: RON, BRIAN, IVAN, NEED HELPRe: paul paul 11/18/01 11:01PM
