Re: ron, brian???
paul /
ok i screwed up...... theres a # 68 jet in there. i already removed three layers from air box, and removed head gasket brian.( recommended by you awhile back). here we go..... the throttle needle was on the second notch from top when i got the carb. moved it to first notch from top. still bogging.... ron whats happening is its hesitating when i give it gas.( i call that bogging). it still did it with the needle position change. it seems to be four stroking at top speed. so like freds guide says, i removed air box and test rode it. seemed to be better. by the way i did a plug chop after needle position changes,and air box removel. plug seems fine not too light, and not too dark....... i LITTLE tan in the center, but dark on the outside. do i need to go to the third position on the needle, and do a plug chop, or go down to a # 66 jet size?????? sorry to be so long. but its driving me CRAZY!!!! please help......
  14mm bing carbTopic by: paul paul 11/12/01 05:32PM
  Re: 14mm bing carbRe: Ron Brown Ron Brown 11/13/01 10:24AM
  Re: Slide NeedleRe: Brian Brian 11/13/01 11:48AM
  Re: ron, brian???Re: paul paul 11/13/01 04:38PM
  Re: ron, brian???Re: Ron Brown Ron Brown 11/13/01 08:01PM
  Re: ron, brian???Re: Brian Brian 11/13/01 09:11PM
  Re: bing carbRe: Charles Charles 11/13/01 05:56PM
  Re: NEW INFORMATION!!Re: paul paul 11/18/01 08:38PM
  Re: NEW INFORMATION!!Re: Ron Brown Ron Brown 11/19/01 12:10PM
  Re: RON, BRIAN, IVAN, NEED HELPRe: paul paul 11/18/01 11:01PM
