Re: Slide Needle
Brian /
Adjust the slide needle, try moving it up a notch, then down a notch from the original location before replacing the main jet with a bigger one. This is time consuming because every adjustment you make to the carb will require a test run and a plug reading. I'll tell you what I've got in mine, it's a 2hp Cobra with a 14mm carb and manifold. It's got a 68 main jet and a 2,17 needle jet which is set in the first notch from the top. I've removed the head gasket, 3 perforated metal discs from the intake ( Cobra's don't have the white plastic snorkle ), and drilled holes in the exhaust pipe insert, so be warned, this may not work on yours unless it's set up like mine but it should get you in the ballpark.
  14mm bing carbTopic by: paul paul 11/12/01 05:32PM
  Re: 14mm bing carbRe: Ron Brown Ron Brown 11/13/01 10:24AM
  Re: Slide NeedleRe: Brian Brian 11/13/01 11:48AM
  Re: ron, brian???Re: paul paul 11/13/01 04:38PM
  Re: ron, brian???Re: Ron Brown Ron Brown 11/13/01 08:01PM
  Re: ron, brian???Re: Brian Brian 11/13/01 09:11PM
  Re: bing carbRe: Charles Charles 11/13/01 05:56PM
  Re: NEW INFORMATION!!Re: paul paul 11/18/01 08:38PM
  Re: NEW INFORMATION!!Re: Ron Brown Ron Brown 11/19/01 12:10PM
  Re: RON, BRIAN, IVAN, NEED HELPRe: paul paul 11/18/01 11:01PM
