Re: Replace your points w/electronic
Michael Reed /
Hi Paul,
My module & installation instructions has stumped 2 of my electrical engineering co-workers, so I'm not overly hopeful. There are only 2 wires coming off the module (see attached photo), and one is supposed to go to case-ground. So it's impossible for the unit to "break" a connection. The best it could do would be to attempt to pull the line to GND. Can you explain the difference between a moped engine & a lawnmower engine?
Thanks,
Mike (MA)
  Replace your points w/electronicTopic by: Brian Brian 11/11/01 12:15PM
  Re: Replace your points w/electronicRe: Mike (MA) Mike (MA) 11/11/01 08:20PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 05:19AM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 06:13AM
  Re: Replace your points w/electronicRe: Roberto Roberto 11/12/01 11:22AM
  Re: Replace your points w/electronicRe: SteelToad SteelToad 11/12/01 02:06PM
  Re: Replace your points w/electronicRe: ken ken 11/12/01 06:45PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/16/01 03:46PM
  Re: Replace your points w/electronicRe: mopedmonster mopedmonster 12/05/01 12:00AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/06/02 09:10PM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/06/02 09:27PM
  Re: Replace your points w/electronicRe: Casey B Casey B 11/06/02 10:59PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/08/02 11:37AM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/08/02 09:00PM
  Re: Ike, You replace your points w/electronicRe: Michael Reed Michael Reed 11/19/02 07:13PM
  Re: Ike, You replace your points w/electronicRe: Tab Patterson Tab Patterson 11/19/02 11:22PM
  Here is the Link for the CDIRe: Bill W Bill W 11/08/02 10:48PM
  Re: Ike, You replace your points w/electronicRe: Freeman Montgomery Freeman Montgomery 11/19/02 07:28PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/20/02 06:19PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/20/02 11:55PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/21/02 04:24AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/21/02 09:08AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/21/02 10:24AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/23/02 10:09PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:04AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:48PM
  Re: Replace your points w/electronicRe: Matt Wilson Matt Wilson 11/24/02 10:58AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:54PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:43PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 02:09PM
