Re: Ike, You replace your points w/electronic
Freeman Montgomery /
"Electronic Ignition" is the elimination of points. from 1973 to the mid 80's American Automoblies had ignition systems that did not have points, but they also did not have a CDI unit. An 'electronic ignition' does not have to have a CDI unit to replace the points, just a way of turning low tension voltage to the coil (6 or 12v) on and off to induce high tension (15 to 50kv) voltage in the coil. usually on a regular unit, they use a pick-up unit in the distributor to replace thwe points wired to a transistor (an electronic 'switch') to turn the current leading to the coil on and off.
  Replace your points w/electronicTopic by: Brian Brian 11/11/01 12:15PM
  Re: Replace your points w/electronicRe: Mike (MA) Mike (MA) 11/11/01 08:20PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 05:19AM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 06:13AM
  Re: Replace your points w/electronicRe: Roberto Roberto 11/12/01 11:22AM
  Re: Replace your points w/electronicRe: SteelToad SteelToad 11/12/01 02:06PM
  Re: Replace your points w/electronicRe: ken ken 11/12/01 06:45PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/16/01 03:46PM
  Re: Replace your points w/electronicRe: mopedmonster mopedmonster 12/05/01 12:00AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/06/02 09:10PM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/06/02 09:27PM
  Re: Replace your points w/electronicRe: Casey B Casey B 11/06/02 10:59PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/08/02 11:37AM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/08/02 09:00PM
  Re: Ike, You replace your points w/electronicRe: Michael Reed Michael Reed 11/19/02 07:13PM
  Re: Ike, You replace your points w/electronicRe: Tab Patterson Tab Patterson 11/19/02 11:22PM
  Here is the Link for the CDIRe: Bill W Bill W 11/08/02 10:48PM
  Re: Ike, You replace your points w/electronicRe: Freeman Montgomery Freeman Montgomery 11/19/02 07:28PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/20/02 06:19PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/20/02 11:55PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/21/02 04:24AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/21/02 09:08AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/21/02 10:24AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/23/02 10:09PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:04AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:48PM
  Re: Replace your points w/electronicRe: Matt Wilson Matt Wilson 11/24/02 10:58AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:54PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:43PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 02:09PM
