Re: Ike, You replace your points w/electronic
Michael Reed /
Hi Ike,
You said you added one of these little electro-ignitions to your Whizzer... I just got mine in the mail today from Northern Tool. There are instructions, but they imply that it's not crucial _where_ the module is screwed down. So if it can go anywhere, how does it know when to create spark (i.e. break)? And how can timing me adjusted?
Here are my guesses to those questions:
1) It senses piston position by sensing the capacitance seen thru the sparkplug, and fires just before that capacitance becomes minimum value;
2) Timing can't be adjusted at all.
Thanks,
Mike (MA)
  Replace your points w/electronicTopic by: Brian Brian 11/11/01 12:15PM
  Re: Replace your points w/electronicRe: Mike (MA) Mike (MA) 11/11/01 08:20PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 05:19AM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 06:13AM
  Re: Replace your points w/electronicRe: Roberto Roberto 11/12/01 11:22AM
  Re: Replace your points w/electronicRe: SteelToad SteelToad 11/12/01 02:06PM
  Re: Replace your points w/electronicRe: ken ken 11/12/01 06:45PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/16/01 03:46PM
  Re: Replace your points w/electronicRe: mopedmonster mopedmonster 12/05/01 12:00AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/06/02 09:10PM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/06/02 09:27PM
  Re: Replace your points w/electronicRe: Casey B Casey B 11/06/02 10:59PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/08/02 11:37AM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/08/02 09:00PM
  Re: Ike, You replace your points w/electronicRe: Michael Reed Michael Reed 11/19/02 07:13PM
  Re: Ike, You replace your points w/electronicRe: Tab Patterson Tab Patterson 11/19/02 11:22PM
  Here is the Link for the CDIRe: Bill W Bill W 11/08/02 10:48PM
  Re: Ike, You replace your points w/electronicRe: Freeman Montgomery Freeman Montgomery 11/19/02 07:28PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/20/02 06:19PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/20/02 11:55PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/21/02 04:24AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/21/02 09:08AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/21/02 10:24AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/23/02 10:09PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:04AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:48PM
  Re: Replace your points w/electronicRe: Matt Wilson Matt Wilson 11/24/02 10:58AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:54PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:43PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 02:09PM
