Re: Replace your points w/electronic
Roberto /
Hmmm, I'm a little bit skeptical too. Replacing a stator and flywheel, and buying a CDI all for $11 sounds a little too good to be true. That's what a true "kit" would have to have. I'm thinking that it's just a CDI unit (the type that requires an external HT Coil). These are manufactured by Piaggio for around $12 last time I looked at them. But you still don't have the HT Coil, stator, and flywheel. Keep us all posted though 'cause electronic ignition is definitely the way to go for reliability.
  Replace your points w/electronicTopic by: Brian Brian 11/11/01 12:15PM
  Re: Replace your points w/electronicRe: Mike (MA) Mike (MA) 11/11/01 08:20PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 05:19AM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/12/01 06:13AM
  Re: Replace your points w/electronicRe: Roberto Roberto 11/12/01 11:22AM
  Re: Replace your points w/electronicRe: SteelToad SteelToad 11/12/01 02:06PM
  Re: Replace your points w/electronicRe: ken ken 11/12/01 06:45PM
  Re: Replace your points w/electronicRe: don-ohio don-ohio 11/16/01 03:46PM
  Re: Replace your points w/electronicRe: mopedmonster mopedmonster 12/05/01 12:00AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/06/02 09:10PM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/06/02 09:27PM
  Re: Replace your points w/electronicRe: Casey B Casey B 11/06/02 10:59PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/08/02 11:37AM
  Re: Replace your points w/electronicRe: Shane Wolfe Shane Wolfe 11/08/02 09:00PM
  Re: Ike, You replace your points w/electronicRe: Michael Reed Michael Reed 11/19/02 07:13PM
  Re: Ike, You replace your points w/electronicRe: Tab Patterson Tab Patterson 11/19/02 11:22PM
  Here is the Link for the CDIRe: Bill W Bill W 11/08/02 10:48PM
  Re: Ike, You replace your points w/electronicRe: Freeman Montgomery Freeman Montgomery 11/19/02 07:28PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/20/02 06:19PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/20/02 11:55PM
  Re: Replace your points w/electronicRe: Ike Fist Ike Fist 11/21/02 04:24AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/21/02 09:08AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/21/02 10:24AM
  Re: Replace your points w/electronicRe: Tab Patterson Tab Patterson 11/23/02 10:09PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:04AM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:48PM
  Re: Replace your points w/electronicRe: Matt Wilson Matt Wilson 11/24/02 10:58AM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 12:54PM
  Re: Replace your points w/electronicRe: Paul D Paul D 11/24/02 01:43PM
  Re: Replace your points w/electronicRe: Michael Reed Michael Reed 11/24/02 02:09PM
