Re: manifold gasket
Ron Brown /
Miguel,
Metal is not a good gasket material except for cylinder heads sometimes.
If this is the carb to manifold gasket and it is a slip on cylindrical fitting, try to find an o-ring of the correct diameter to match the outer diameter of the inner part and the inner diameter of the outer part, this should squish as you install the carb.
If you are repacing a flat gasket beween two flat surfaces, buy intake manifold gasket material at an auto parts store. If you are carefull making it, this will be as good as the original.
Ron
  cold air better??Topic by: paul paul 11/07/01 08:52PM
  Re: cold air better??Re: Wayne Wayne 11/07/01 09:16PM
  Re: cold air better??Re: paul paul 11/07/01 10:20PM
  Two reasonsRe: Fred Fred 11/07/01 09:35PM
  Re: Two reasonsRe: Doug D. Doug D. 11/07/01 10:47PM
  I wishRe: KoLD KoLD 11/07/01 11:18PM
  Then its screwed up... nmRe: Fred Fred 11/07/01 11:33PM
  Re: Then its screwed up... nmRe: miguel miguel 11/08/01 12:29AM
  Re: Then its screwed up... nmRe: Motoman Motoman 11/08/01 04:52PM
  Well,Motoman........Re: don-ohio don-ohio 11/08/01 10:21PM
  Re: I wishRe: Jamie Jamie 11/09/01 01:04AM
  manifold gasketRe: miguel miguel 11/09/01 01:54AM
  Re: manifold gasketRe: don-ohio don-ohio 11/09/01 02:09AM
  Re: manifold gasketRe: miguel miguel 11/09/01 02:14AM
  Re: manifold gasketRe: don-ohio don-ohio 11/09/01 02:29AM
  Re: manifold gasketRe: Ron Brown Ron Brown 11/09/01 11:16AM
  Re: manifold gasketRe: miguel miguel 11/09/01 12:04PM
