Well,Motoman........
don-ohio /
........you probably need to either clean your air filter or check for clogged exhaust.If that's not it,increase your air flow by opening up your air box(remove inserts or drill a coupla' 3/8 air holes).Then do a plug chop on a good spark plug to make sure you're not running too lean.
  cold air better??Topic by: paul paul 11/07/01 08:52PM
  Re: cold air better??Re: Wayne Wayne 11/07/01 09:16PM
  Re: cold air better??Re: paul paul 11/07/01 10:20PM
  Two reasonsRe: Fred Fred 11/07/01 09:35PM
  Re: Two reasonsRe: Doug D. Doug D. 11/07/01 10:47PM
  I wishRe: KoLD KoLD 11/07/01 11:18PM
  Then its screwed up... nmRe: Fred Fred 11/07/01 11:33PM
  Re: Then its screwed up... nmRe: miguel miguel 11/08/01 12:29AM
  Re: Then its screwed up... nmRe: Motoman Motoman 11/08/01 04:52PM
  Well,Motoman........Re: don-ohio don-ohio 11/08/01 10:21PM
  Re: I wishRe: Jamie Jamie 11/09/01 01:04AM
  manifold gasketRe: miguel miguel 11/09/01 01:54AM
  Re: manifold gasketRe: don-ohio don-ohio 11/09/01 02:09AM
  Re: manifold gasketRe: miguel miguel 11/09/01 02:14AM
  Re: manifold gasketRe: don-ohio don-ohio 11/09/01 02:29AM
  Re: manifold gasketRe: Ron Brown Ron Brown 11/09/01 11:16AM
  Re: manifold gasketRe: miguel miguel 11/09/01 12:04PM
