RE: Can't remove exhaust baffle from Puch Korado!
Ivo /
<HTML>Removing the baffles on 2-strokes gives a better performence in 90% of the cases, because 2-strokes mostly have those baffles as restrictors. Don't use excessive force to remove it, try some WD40 or maybe there's a screw you missed. Some people actually saw off the end of their exhaust, don't do this unless you have a good replacement exhaust in case you ruin it. The best (not the cheapest) thing to do is to buy an exhaust without baffles and with a thicker pipe, that's what I did with my Honda MT50. Special exhausts give the best performance and improve the sound your bike make's.
P.S. If you remove the baffle, saw it off or replace the whole exhaust, you should recalibrate your carburettor.</HTML>
  Can't remove exhaust baffle from Puch Korado!Topic by: TaTommy TaTommy 04/24/00 02:29PM
  RE: Can't remove exhaust baffle from Puch Korado!Re: Ivo Ivo 04/27/00 06:53AM
