no spark
<HTML>i got an old moped. The headlight works when u crank it. But theres no spark. any reasons why?</HTML>
RE: no spark
Matt Schmitt /
<HTML>the spark control box is probably busted. Its the box that the spark wire is connected to. the headlight works because the magneto still works.</HTML>
RE: no spark
<HTML>Check the contactbreakers, the condensor, the bobine, the grounding, the HT-wire and the HT-clip, can't be anything else.</HTML>
RE: no spark
<HTML>As long as the bike doesn't use a solidstate ignition, its propably just a bad conection or a burned out coil or plug. Try cleaning it all up at the contact points (places where wires are joined, etc.)
Good Luck and Have Fun,
john
(the other john)</HTML>
RE: no spark
<HTML>what name and type ect. might help?</HTML>
