Re: more vespa problems :-(
Chris S /
When I've had air leaks, it has been one of two places: the carb wasn't fully on the manifold and tight, or the top (the throttle slide cover) wasn't tightened down. You can tell if you can get it started, then spray carb cleaner or WD40 on the carb while it is running. If the engine idle changes, then there is a leak. It sucks the liquid in through the leak and then burns it, changing the fuel/air mix.
Good luck.
Chris
  more vespa problems :-(Topic by: miguel miguel 11/05/01 03:22PM
  Re: more vespa problems :-(Re: XBrandon EdgeX XBrandon EdgeX 11/05/01 03:28PM
  Re: more vespa problems :-(Re: Ron Brown Ron Brown 11/05/01 04:07PM
  Re: more vespa problems :-(Re: miguel miguel 11/05/01 05:30PM
  Re: more vespa problems :-(Re: Mike (MA) Mike (MA) 11/05/01 05:35PM
  Re: more vespa problems :-(Re: Chris S Chris S 11/05/01 06:02PM
  Re: more vespa problems :-(Re: miguel miguel 11/05/01 06:19PM
  Re: more vespa problems :-(Re: Chris S Chris S 11/05/01 07:17PM
  Re: more vespa problems :-(Re: miguel miguel 11/05/01 07:37PM
  Re: I did once..Re: Jim C. Jim C. 11/05/01 10:23PM
  Re: I did once..Re: Chris S Chris S 11/05/01 11:38PM
  Re: At the beginning..Re: Jim C. Jim C. 11/06/01 11:02AM
  Re: At the beginning..Re: miguel miguel 11/06/01 12:18PM
  Re: At the beginning..Re: Ron Brown Ron Brown 11/06/01 02:58PM
  You could also check..Re: Jim C. Jim C. 11/06/01 10:24PM
