Re: more vespa problems :-(
miguel /
i've considered most of those. but the grande ran strong until i messed w/ it ... so i'm guessing that i can narrow it down. i'm familiar w/ the dellorto (and other than the size, it was essentially the same as a 14.12 or similar model) and so i'm pretty sure i put it all back together properly.
i'm thinking it might be that the carb is not on tight enough, so that it has air leaking. i'll take it all out (again!) and fiddle w/ it some more next time i have time and it's a nicer day out.
i'm thinking that maybe i'll need to figure out a way to make sure the carb is tight on the manifold ... that might be the culprit.
oy! ... but i'll keep working ...
  more vespa problems :-(Topic by: miguel miguel 11/05/01 03:22PM
  Re: more vespa problems :-(Re: XBrandon EdgeX XBrandon EdgeX 11/05/01 03:28PM
  Re: more vespa problems :-(Re: Ron Brown Ron Brown 11/05/01 04:07PM
  Re: more vespa problems :-(Re: miguel miguel 11/05/01 05:30PM
  Re: more vespa problems :-(Re: Mike (MA) Mike (MA) 11/05/01 05:35PM
  Re: more vespa problems :-(Re: Chris S Chris S 11/05/01 06:02PM
  Re: more vespa problems :-(Re: miguel miguel 11/05/01 06:19PM
  Re: more vespa problems :-(Re: Chris S Chris S 11/05/01 07:17PM
  Re: more vespa problems :-(Re: miguel miguel 11/05/01 07:37PM
  Re: I did once..Re: Jim C. Jim C. 11/05/01 10:23PM
  Re: I did once..Re: Chris S Chris S 11/05/01 11:38PM
  Re: At the beginning..Re: Jim C. Jim C. 11/06/01 11:02AM
  Re: At the beginning..Re: miguel miguel 11/06/01 12:18PM
  Re: At the beginning..Re: Ron Brown Ron Brown 11/06/01 02:58PM
  You could also check..Re: Jim C. Jim C. 11/06/01 10:24PM
