<HTML>I had the same problem. 1 make sure you have gas going to the carb. 2 remove
carb. disasemble and clean everthing with gumout. I removed the filter screen
from the carb. and installed a clear plastic gas line filter in the gas line. This
should get you up and running... Let me know</HTML>
