RE: '78 Puch wont start
Ryan /
<HTML>Here is an idea - - you might not be getting fuel to the carb, or the carb itself is plugged up tight. Remove the carb and the fuel line, and make certain each is clear (bloe air with a compressor through the fuel inlet of the carb. If you hear a LOT of air rushing - it's ok) - and make certain your line is ok. Then check to see if gas comes out of the fuel shut off valve when turned ON.
Ryan</HTML>
  '78 Puch wont startTopic by: Marty M Marty M 04/20/00 10:51AM
  RE: '78 Puch wont startRe: Jim C. Jim C. 04/20/00 12:11PM
  RE: '78 Puch wont startRe: Ryan Ryan 04/20/00 12:18PM
  RE: '78 Puch wont startRe: bill bill 04/21/00 08:06PM
  RE: '78 Puch wont startRe: WesParker WesParker 05/21/00 09:49PM
  RE: '78 Puch wont startRe: Harry Davis Harry Davis 05/28/00 09:36PM
