Question for Tomos Owners?
Well i rewired my targa back up and everything works perfect except it doesnt spark any more, there are 3 wires that go on the cdi box bolts, 2 are browns(the grounds) and 1 is black, if the black metal circle at the end of the wire touches either of the brown circles will it cause it not to start? if not what could be the cause of this? I really badly wanna get on the road with this bike before it starts snowing...... HELP!
Re: Question for Tomos Owners?
Reeperette /
The ground wires are both run to the same spot - the bolt holding the CDI box on, usually the lower one.
The black wire goes to the metal tab located on the CDI box, usually right below the plug wire.
That should help some.
-R
