<HTML>I have a problem: How do I get a Honda X8R-X tuned harder then 60 km/u km/ph?
Without changing Cilinder only other exaust (pipe)
Suggetions????????????</HTML>
Hi fran, i'm answering to your MOpedarmy question !
i have an X8R and I had that 60 km/h too
just buy a LeoVinci exhaust and you problem will be fixed
for better performance, change the CDI to a rotation higher than 8000 rpm!!
please anwer me tellin' if U received this
greentings from Portugal :-)
wel i have a honda x8r and it goes like 70 without changing a thing
But you can always fit a part on your air cooler so it sucks more air=>faster
you can also put weights on your flywheel you'll accelerate faster but you wont go faster in speed
hope i helped ya a bit
HEy new tip: fit the weights and the springs wich are included with tha zx from leovinci and otherwise remove the twa plates arround your flywheel
send me some tunes x8r-pics please!!
how do i change the cdi or rotate it to 8000rpm and where is it located thanks to anyone who can help at all
how do i rotate the cdi and also where is it located
