Re: How should it be stored???
don-ohio /
Yes,Mr.Band! Put the correct amount of `Sta-Bil' fuel stabilizer in the tank and top it up.Then close the fuel valve on the tank and run the `ped until you know it's about to stop.A full tank won't rust.Make sure to only use quality gas with NO ETHANOL.Ethanol attracts moisture into your gas.Let excess air out of the tires,down to about 20 lbs. is o.k.,and lube the chain with grease or 90 W gearoil.Spray inside the cables with silicone spray or light oil.Remove the spark plug and pour in a little 2-cycle oil and turn the engine over with the plug removed.Then replace the plug.Make a list of these things you've done for future reference and don't forget to air up the tires in the spring or whenever you plan on using it.
  Time to hibernate the moped!Topic by: Jamie Leonard Jamie Leonard 11/01/01 09:26AM
  Re: Time to hibernate the moped!Re: gimmyjimmy gimmyjimmy 11/01/01 09:41AM
  Re: Time to hibernate the moped!Re: Jamie Leonard Jamie Leonard 11/01/01 11:21AM
  Re: Time to hibernate the moped!Re: Ron Brown Ron Brown 11/01/01 11:28AM
  Re: Time to hibernate the moped!Re: don-ohio don-ohio 11/01/01 11:30AM
  Re: Time to hibernate the moped!Re: Ron Brown Ron Brown 11/01/01 11:51AM
  Again,Ron,great help! ThanksRe: don-ohio don-ohio 11/01/01 12:24PM
  Re: Try a themal hunting suitRe: Rog Rog 11/01/01 03:42PM
  Re: Try a themal hunting suitRe: don-ohio don-ohio 11/01/01 03:57PM
  Re: Time to hibernate the moped!Re: Jamie Leonard Jamie Leonard 11/01/01 12:32PM
  Re: Time to hibernate the moped!Re: Ron Brown Ron Brown 11/01/01 01:01PM
  Re: Time to hibernate the moped!Re: Jamie Leonard Jamie Leonard 11/01/01 01:35PM
  Hibernate the moped ? Blasphemy !Re: Reeperette Reeperette 11/01/01 12:47PM
  Re: Hibernate the moped ? Blasphemy !Re: Jamie Leonard Jamie Leonard 11/01/01 03:11PM
  There's that.Re: Reeperette Reeperette 11/01/01 03:16PM
  Re: There's that.Re: don-ohio don-ohio 11/01/01 03:30PM
  Re: There's that.Re: Jamie Leonard Jamie Leonard 11/01/01 03:54PM
  Re: There's that.Re: don-ohio don-ohio 11/01/01 04:02PM
  Re: There's that.Re: Jamie Leonard Jamie Leonard 11/01/01 04:27PM
  Re: There's that.Re: don-ohio don-ohio 11/01/01 05:03PM
  Re: Hibernate the moped ? Blasphemy !Re: Tom C Tom C 11/02/01 04:19AM
  Tire Chains.Re: Reeperette Reeperette 11/02/01 02:09PM
  How should it be stored???Re: Jessie S. Band Jessie S. Band 11/12/01 06:30AM
  Re: How should it be stored???Re: don-ohio don-ohio 11/12/01 06:55AM
