Kinetic TFR Engine Serial #?
Do the Kinetic TFRs have an engine serial number? I have looked and can't easily find it. Thanks.
Re: Kinetic TFR Engine Serial #?
Yes they do.The guy at motor vehicles had to see mine when I regestered it.I also had a hard time finding it.I believe it's on the right side of the engine,under the plastic sidecover.If nobody else answers your question,I'll look at mine tomorrow and let you know.
On the Kinetic TFR-USA,the engine number is on the right side(exhaust side) of the engine,at the very bottom.You need to take off the plastic sidecover to see it clearly.Look just below the coil,and just above the exhaust pipe.The numbers are VERY small,if the area is dirty,you will have to clean it before you can see the numbers.I don't know if the older model TFR has the engine number in the same place or not,but they probably do.
Thanks, Jerry, found them! Etched in the case as well as on a little sticker that was readable. Thanks again!
