Re: Tomos Idle help.
ivan /
if its idleing to low its one of five things
1 you need to turn the little idle screw in
2 the mixture is to rich or to lean make sure you have the correct jet in it
3 the rings are worn
4 a seal is out possibly the trans side which would cause it to cut off at idle
5 carb is dirty
  Tomos Idle help.Topic by: Arterious Arterious 10/31/01 05:50PM
  Re: Tomos Idle help.Re: Reeperette Reeperette 10/31/01 05:58PM
  Re: Tomos Idle help.Re: Arterious Arterious 10/31/01 06:02PM
  Re: Tomos Idle help.Re: Reeperette Reeperette 10/31/01 09:41PM
  Re: Tomos Idle help.Re: ivan ivan 11/04/01 12:25AM
