Re: HexBolts Sucketh.
Ron Brown /
Ree,
You need a set of allen wrenches designed to fit a 3/8 drive ratchet and if necessary, an adaptor to an impact wrench. Failing that, cut a straight length off the allen wrench, set it in the bolt head and whack it. If you can, use a long enough wrench to clamp vise grips on it and apply sone counter clockwise pressure as you hit it. Then try to unscrew it again. All of the hold of a bolt, if not corroded, is the binding of the head to the surface by the pulling of the thread. Whacking it with an impact wrench or as described, shortens the distance between the head face and the threads. This will almost allways loosen it.
Happy hammering,
Ron
  HexBolts Sucketh.Topic by: Reeperette Reeperette 10/31/01 04:10PM
  Re: HexBolts Sucketh.Re: Steeltoad Steeltoad 10/31/01 04:19PM
  Re: HexBolts Sucketh.Re: Ron Brown Ron Brown 10/31/01 04:33PM
  Re: HexBolts Sucketh.Re: Reeperette Reeperette 10/31/01 04:42PM
  Re: HexBolts Sucketh.Re: Chris Chris 10/31/01 05:16PM
  Re: HexBolts Sucketh.Re: Vespalad Vespalad 10/31/01 05:26PM
  Jeez...schools these days....Re: Reeperette Reeperette 10/31/01 05:55PM
  Re: HexBolts Sucketh.Re: Rog Rog 10/31/01 09:35PM
  Re: HexBolts and more Schoolin'Re: Jim C. Jim C. 10/31/01 10:21PM
  Having the tools don't help much.Re: Reeperette Reeperette 11/01/01 12:23PM
  Re: Having the tools don't help much.Re: Jamie Jamie 11/01/01 03:34PM
  Re: Having the tools don't help much.Re: don-ohio don-ohio 11/01/01 03:52PM
  Re: Having the tools don't help much.Re: Ron Brown Ron Brown 11/01/01 04:17PM
  Re: Having the tools don't help much.Re: don-ohio don-ohio 11/01/01 04:49PM
  Re: Having the tools don't help much.Re: Ron Brown Ron Brown 11/01/01 05:41PM
  Leftovers....Re: Reeperette Reeperette 11/01/01 05:53PM
  Re: Leftovers....Re: don-ohio don-ohio 11/01/01 06:37PM
  Re: Having the tools don't help much.Re: don-ohio don-ohio 11/01/01 06:29PM
  Re: An impact driver!Re: Jim C. Jim C. 11/01/01 09:56PM
