A genuine Avanti 65cc cylinder kit is available from
The other person is correct I had problems with the clutch on my supersport but I'd like to point out they had modified the clutch so the larger size piston is unrelated however I can tell you that it does add quite a bit of additional vibration...However it will also make it quite a bit faster on take off...
