Yep.
Reeperette /
It's held to the frame by a ring-nut kinda thing, and if yer lucky it has little grips on the nut you can put a screwdriver to, in case you hafta hammer it loose.
It might be under a plastic cover or somethin, but it DOES come off....I should know, having mounted a 1978 Puch Maxi Front end to a 1974 Tomos rear frame.
What surprised the hell outta me was that it fit !
Take yer electrical connections and run a bit of tape with a label on it around each end, so you know what hooks up to what when you put it back on.
That would also be a nice time to reverse yer brake cables, if you wanna use that idea, as well.
-R
  ForksTopic by: SteelToad SteelToad 10/30/01 12:53PM
  Yep.Re: Reeperette Reeperette 10/30/01 07:44PM
  Re: Yep.Re: Steeltoad Steeltoad 10/31/01 01:23AM
  Re: Yep.Re: Reeperette Reeperette 10/31/01 09:03AM
  Re: Yep.Re: Ron Brown Ron Brown 10/31/01 12:01PM
  Well, in case of that....Re: Reeperette Reeperette 10/31/01 03:57PM
  Re: Well, in case of that....Re: Ron Brown Ron Brown 10/31/01 04:36PM
  Point takenRe: Reeperette Reeperette 10/31/01 09:22PM
