Re: 80 Moby Carb questions
Ron Brown /
....returns from garage administering "dope slaps" with both hands alternately...
OK, forget what I said many posts ago about brass slugs with rubber tips blocking gas passages. This is true of every Jap bike I ever disassembled but I obviously underestimated the deviousness of the French!
Here is how the "choke" works. The hole into which the brass slug fits is drilled all the way through the carb body (if anyone is aware of any plug or cap for the bottom end of this hole I would like to hear about it). The diameter of the hole is stepped to a slightly smaller diameter about half way down. The brass slug is also stepped in diameter so that if you drop it in the choke opening, the step on the brass slug sets on the step in the bore. The slug is a sliding fit in the choke bore for both diameters. A hole is drilled from the engine side of the carb venturi, through the choke bore and into the float bowl. This hole passes through the choke bore larger diameter just above the step to the smaller diameter. With the slug in its lowest position, the large diameter of the slug covers these small holes on either side of choke bore. This is the choke off position. When the slug is raised by the cable, the larger diameter of the slug is raised above the through hole which is now in line with the smaller diameter of the brass slug. This creates a cavity between the small diameter of the choke bore and the large diameter of the brass slug. Vacuum in the intake causes fuel to be sucked through this cavity, around the brass slug and into the intake.
Is this prone to leakage of gas and sucking in dirt? Sure, but it is French!
Ok, now to putting yours back together.
I am fairly sure that the nylon piece you have is the piece the outer case of the cable fits into on top of the carb. Before you start you may want to verify that the cable case fits into one end of this plastic piece. Mine is different, the placement of my carb requires this piece to have a severe bend as it leaves the carb.
Using a 10 speed gear shift cable inner, thread onto the end without a nipple, the brass slug, small diameter first. Then the spring, followed by the brass washer(I think dimple down but see how it mates with the nylon cable guide and carb top). Lastly, the nylon sleeve, with the cable sheath end on last.
Assemble the choke mechanism to the carb top with the carb top between the spring and the brass washer. Install the carb top. Slip the outer cable over the inner and check for length to the choke control. If required, slide the outer back off and cut to length. Shorten the cable adjuster on the control, fit the inner cable in the cable clamp in the choke control leaving about 1/16" of play in the cable with the control in the off position.
Hope this works for you,
Ron
  80 Moby Carb questionsTopic by: Pat Finley Pat Finley 10/30/01 01:23AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/30/01 11:04AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 01:28PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 01:59PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:07PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:28PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:31PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:40PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:43PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:41PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:46PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:49PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:58PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 03:13PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 03:25PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 04:04PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 05:18PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 07:24PM
  Re: 80 Moby Carb questionsRe: Simon King Simon King 10/31/01 05:16PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 08:31PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 01:38AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 02:16AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 04:04AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:43AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:44AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:46AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:47AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:48AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:49AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 12:47PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 01:11PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 02:24PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 03:03PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 03:06PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 05:35PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 05:42PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 06:07PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/02/01 11:40PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/06/01 02:52AM
