Re: 80 Moby Carb questions
Ron Brown /
Pat,
I am now on information overload! Great pictures!
I just gave myself a huge "dope slap" when it dawned on me that when you refered to the cable being installed from the bottom, you meant the bottom of the choke internals. All this time I was under the impression that the cable entered the carb from the bottom instead of the top.
I had never considered this as I have not disassembled my choke mechanism from the cable. It is now obvious to me that cable installation involves threading all the components onto the cable then threading the cable back into the outer case. The control end is then clamped by a screw clamp.
Time out to consult manual....
My manual shows what looks like your plastic piece going into the carb first (the brass piece may be inside this), then the spring. In the cable replacement section, it talks about replacing the cable as I described above.
In the manner of all good shop manuals, it is just short of explaining it in enough detail to be able to resurect a handfull of parts. You have to have a complete carb to look at.
It appears that no one with a carb in hand is going to respond here and that you will continue to inundate us with jpegs until this puzzle is solved. : )
Sighs and heads for garage to pull carb of ped....
Will post results.
Ron
  80 Moby Carb questionsTopic by: Pat Finley Pat Finley 10/30/01 01:23AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/30/01 11:04AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 01:28PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 01:59PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:07PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:28PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:31PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:40PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:43PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:41PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:46PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:49PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:58PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 03:13PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 03:25PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 04:04PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 05:18PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 07:24PM
  Re: 80 Moby Carb questionsRe: Simon King Simon King 10/31/01 05:16PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 08:31PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 01:38AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 02:16AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 04:04AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:43AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:44AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:46AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:47AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:48AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:49AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 12:47PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 01:11PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 02:24PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 03:03PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 03:06PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 05:35PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 05:42PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 06:07PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/02/01 11:40PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/06/01 02:52AM
