80 Moby Carb questions
Pat Finley /
I was hoping for some help from the experts out there.
Finally got my Moby to start after many years. But there must be a fuel flow problem because it won't idle. I took apart the carb and throughly cleaned it, but I must have screwed something up with the choke.
Part of my problem is that my choke cable is severed. So, I am not able to "choke" when attempting to start it. So, I guess I can't tell if the carb is blocked because it may be that I need to 'choke', but I can't. I don't really know what the choke is supposed to do, so that's another part of my problem. (I only know that you typically start the moped with choke action.)
After cleaning the carb, I must have put the choke back together improperly because fuel is leaking out the bottom. Anybody know how it goes on an '80 Moby? I know that somehow the cable comes in from the bottom of the carburetor and applies some sort of pressure that opens a valve - I think. I'm working with 3 pieces, a brass piece with a hole the width of the tension cable, a spring, and a white plastic piece (also with a hole the width of the tension cable). I can't seem to: figure out how to set these 3 pieces to get tension, and, what the choke is actually supposed to do.
Anybody want to help?
Thanks much..
Pat Finley
  80 Moby Carb questionsTopic by: Pat Finley Pat Finley 10/30/01 01:23AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/30/01 11:04AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 01:28PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 01:59PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:07PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:28PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:31PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:40PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:43PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:41PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 02:46PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:49PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 02:58PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 03:13PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 10/31/01 03:25PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 04:04PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 10/31/01 05:18PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 07:24PM
  Re: 80 Moby Carb questionsRe: Simon King Simon King 10/31/01 05:16PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 10/31/01 08:31PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 01:38AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 02:16AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 04:04AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:43AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:44AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:46AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:47AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:48AM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 03:49AM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 12:47PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 01:11PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 02:24PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 03:03PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 03:06PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/01/01 05:35PM
  Re: 80 Moby Carb questionsRe: Ron Brown Ron Brown 11/01/01 05:42PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/01/01 06:07PM
  Re: 80 Moby Carb questionsRe: Pat Finley Pat Finley 11/02/01 11:40PM
  Re: 80 Moby Carb questionsRe: don-ohio don-ohio 11/06/01 02:52AM
