tomos chain
is there like a special way to tighten this?? everytime i try to tighten it the backtire comes loose or the chain comes loose ..
Re: tomos chain
losen both sides and then spin the tensioners so that you get 1/4" of play in the chain, then tighten them up... make sure you LOCK them in place with the inside nut, otherwise it will come loose.. Either this or your chain is old and over-stretched.
