Re: Someone's gotta know......
Don Pflueger /
when adding any performance parts or modifying anything you must upjet and do plug chops. you would also be wise to remove the oil injection since it only pumps at 50:1 and it is desugned to work with the stock bore. but since your increasing volumes all across the board, you should increase your oil as well and run a 40:1 pre mix.
