only runs at high RPMs
Clayton Violand /
My Moped only starts and runs at high RPMs. If i pedal really really really fast on the center stand, and i give it throttle, it will eventually start, then die off as soon as the wheel touches the ground.
Help.
Re: only runs at high RPMs
my puch did that, my problem was a broken piston ring
Could be a bad condensor, check for sparking on the points.
Clayton Violand /
What exactly does the condensor do??? Would this be why everything is getting so hot and it only starts if I pedal really hard? I'm basically trying to decide if the problem is a piston ring or the condensor.
Steamboat Aka J. R. Stevens /
Did your problems just occur or have you made any changes to your ped? Jim.
Clayton Violand /
Well- I was having alot of trouble before. It wouldn't idle and it would shut off after a while after it ran for like 10 minutes (it would slowly slow down then just stop). So I then cleaned the carb (I also took my turn signals off, but the wiring is according to the instruction diagram). Ever since I cleaned the carb . . . .the problem has been magnified. It just won't stay running. It WILL start. . . .but only when I pedal really fast- and if i don't hold the throttle down, then it will die.
