Re: only runs at high RPMs
Clayton Violand /
Well- I was having alot of trouble before. It wouldn't idle and it would shut off after a while after it ran for like 10 minutes (it would slowly slow down then just stop). So I then cleaned the carb (I also took my turn signals off, but the wiring is according to the instruction diagram). Ever since I cleaned the carb . . . .the problem has been magnified. It just won't stay running. It WILL start. . . .but only when I pedal really fast- and if i don't hold the throttle down, then it will die.
