Re: The hells wrong with my ped?
Chris /
D id this start as soon as you picked the moped up. How was it behaving before. If it was just serviced I'll assume that it has a new plug, fresh gas and a clean carburetor. It sounds as though it may have a vacuum leak. We see a lot of Tomos mopeds that have the A-35 engine come in without the stepped rubber intake seal between the carburetor and intake manifold. Also see them come in with the seal backwards. Both will cause simmilar symptoms to what you are describing. In cold weather the symptom is worse because the air is denser when it is cold and the leak will appear to be larger and cause it to run even leaner. Try spraying around the front of the carburetor with carb cleaner while it is idling and see if has any eccect. Might want to spray around the base gasket and reedvalve while your at it.
Chris
  The hells wrong with my ped?Topic by: KoLD KoLD 10/27/01 04:13PM
  Re: The hells wrong with my ped?Re: Ron Brown Ron Brown 10/27/01 04:17PM
  Re: The hells wrong with my ped?Re: miguel miguel 10/27/01 04:26PM
  Re: The hells wrong with my ped?Re: Ron Brown Ron Brown 10/27/01 04:38PM
  Re: The hells wrong with my ped?Re: chuck russo (va) chuck russo (va) 10/27/01 05:27PM
  Re: The hells wrong with my ped?Re: Crisis--Cincinnati Crisis--Cincinnati 10/27/01 07:02PM
  Re: The hells wrong with my ped?Re: chuck russo (va) chuck russo (va) 10/27/01 04:37PM
  not cold here And SAME prob. REE HELP =)Re: Arterious Arterious 10/27/01 06:46PM
  updateRe: Arterious Arterious 10/27/01 07:31PM
  Re: The hells wrong with my ped?Re: Albert Einstein Albert Einstein 10/27/01 08:47PM
  Re: The hells wrong with my ped?Re: Chris Chris 10/27/01 09:35PM
  Imma thinkin clogged airfilter here.Re: Reeperette Reeperette 10/27/01 10:59PM
  Re: AnswersRe: miguel miguel 10/28/01 01:14AM
  Re:had a Harley like that.Re: Rog Rog 10/28/01 05:24PM
  AnswersRe: KoLD KoLD 10/28/01 12:22AM
  Re: The hells wrong with my ped?Re: mike hartel mike hartel 10/29/01 11:49PM
