RE: air/fuel adjustments on carb
David /
<HTML>Mike
I just looked at that carb again.
There is access to the main jet from the outside of the carb.
It is brass and is located at the bottom, below the point where the carb mount mounts.
Remove the carb, then it is easily removed from the carb body with a flat screw driver. Then do your cleaning as necessary.
Dave</HTML>
  air/fuel adjustments on carbTopic by: mike mike 03/09/00 08:16PM
  RE: air/fuel adjustments on carbRe: David David 05/03/00 06:29PM
  RE: air/fuel adjustments on carbRe: David David 05/05/00 02:54PM
  RE: air/fuel adjustments on carbRe: ryan ryan 05/20/00 10:27PM
