Tomos trans fluid
Jamie /
I just got ahold of a tomos moped that someone had tried to fix. I have undone most of what the did to fix it and it will now run. I tried to find some info on how much transmission fluid to put into a Tomos Targa. I had seen a post earlier that had stated 220cc's of motor oil. Does anyone have any suggestions.
Also, it starts to wine in first gear as I get up to 10mph is this a fluid problem or just a worn out 1st gear. I had taken a look at the gear when I had it of (I had to flip the roller bearings over, the person that had tried to fix it had installed them backwards so that when you puched it, the engine was engaged. When you cranked it. The motor just spun). The grear looked OK.
  Tomos trans fluidTopic by: Jamie Jamie 10/24/01 07:49PM
  Re: Tomos trans fluidRe: InfectedBootSector InfectedBootSector 10/24/01 09:22PM
  Re: Tomos trans fluidRe: Reeperette Reeperette 10/24/01 10:38PM
  Re: Tomos trans fluidRe: Jamie Jamie 10/24/01 11:30PM
  Re: Tomos trans fluidRe: brian brian 10/28/01 02:04PM
