Re: aftermarket petcock / fuel shutoff valve
Ron Brown /
Mike,
Now that I have hrassed you into posting this on the forum instead of emailing me directly, I am not sure I can answer your question directly.
I am the proud owner of two tap and die sets, one sae and one metric. The kind that costs about $12.00 So I may have re-cut the thread on the brass fitting that screwed into the tank but I do not recall having to do that. The Motobecane gas tank has a square nut on the inside of the tank, held in place by metal tabs, the petcock screws into this nut and a washer between the petcock and the outside of the tank seals it, so I can't measure the thread without draining the tank and un-screwing the petcock.
My best recollection is that the nut had a standard thread which either matched, or was very close to, the thread on the brass fitting I used. I may, or may not have run a die down the brass fitting to make it fit but I just can't remember. I am sure that I had no real trouble maked it fit.
I hope this helps.
Ron
  aftermarket petcock / fuel shutoff valveTopic by: Mike (MA) Mike (MA) 10/23/01 01:03PM
  Re: aftermarket petcock / fuel shutoff valveRe: Ron Brown Ron Brown 10/23/01 01:30PM
  lawnmower store.... $4Re: Fred Fred 10/23/01 06:54PM
  back yard $.04Re: skatecheap skatecheap 10/23/01 08:39PM
  pedal yer ass on a bicycle ... FREERe: Fred Fred 10/23/01 08:41PM
  FREE, hee,heeRe: skatecheap skatecheap 10/23/01 08:57PM
  Re: aftermarket petcock / fuel shutoff valveRe: Mike (MA) Mike (MA) 10/25/01 05:29PM
  Re: aftermarket petcock / fuel shutoff valveRe: Ron Brown Ron Brown 10/25/01 05:57PM
  Re: aftermarket petcock / fuel shutoff valveRe: Chris Chris 10/25/01 08:07PM
  Tinkerers R' usRe: Ron Brown Ron Brown 10/26/01 10:30AM
  Re: Tinkerers R' usRe: Chris Chris 10/26/01 10:09PM
  Re: Tinkerers R' usRe: Ron Brown Ron Brown 10/27/01 11:55AM
  Re: aftermarket petcock / fuel shutoff valveRe: don-ohio don-ohio 10/23/01 09:27PM
