Re: aftermarket petcock / fuel shutoff valve
Ron Brown /
Mike,
I used these petcocks on my 2 Motobecane Model 7's.
I found a brass fitting at a hardware store with the same thread on one end as the thread in the tank. I silver soldered a brass washer to the base of the thread so that when I screwed it into the tank, I could use a nylon washer to seal it. I cut the other end off the fitting, filed it flat, then tapped it internally. I cut the same thread on one end of the petcock and screwed it into the brass fitting with a nylon washer. You can add and remove washers to get the lever to line up when it is tight.
I have no reserve of course, but have had no problems with these petcocks.
Ron
  aftermarket petcock / fuel shutoff valveTopic by: Mike (MA) Mike (MA) 10/23/01 01:03PM
  Re: aftermarket petcock / fuel shutoff valveRe: Ron Brown Ron Brown 10/23/01 01:30PM
  lawnmower store.... $4Re: Fred Fred 10/23/01 06:54PM
  back yard $.04Re: skatecheap skatecheap 10/23/01 08:39PM
  pedal yer ass on a bicycle ... FREERe: Fred Fred 10/23/01 08:41PM
  FREE, hee,heeRe: skatecheap skatecheap 10/23/01 08:57PM
  Re: aftermarket petcock / fuel shutoff valveRe: Mike (MA) Mike (MA) 10/25/01 05:29PM
  Re: aftermarket petcock / fuel shutoff valveRe: Ron Brown Ron Brown 10/25/01 05:57PM
  Re: aftermarket petcock / fuel shutoff valveRe: Chris Chris 10/25/01 08:07PM
  Tinkerers R' usRe: Ron Brown Ron Brown 10/26/01 10:30AM
  Re: Tinkerers R' usRe: Chris Chris 10/26/01 10:09PM
  Re: Tinkerers R' usRe: Ron Brown Ron Brown 10/27/01 11:55AM
  Re: aftermarket petcock / fuel shutoff valveRe: don-ohio don-ohio 10/23/01 09:27PM
