RE: PA-50 lost compression
Jim C. /
<HTML>Check the easy stuff first. Is the decompressor spring collapsed? Next check to see if the head gasket leaks by having someone crank the motor while you listen for a hiss at the head.
Next is to finally pull the cylinder and see if a piston ring broke. </HTML>
  PA-50 lost compressionTopic by: Jonah Jonah 02/28/00 09:30PM
  RE: PA-50 lost compressionRe: Jim C. Jim C. 02/28/00 10:43PM
  RE: PA-50 lost compressionRe: Shaun Strahm Shaun Strahm 03/07/00 05:59AM
