Brandon,
If you have points, you can run a wire from that splice to the switch and then to ground.
If you have electronic ignition, the switch may have broken that wire.
Check the kill switch, if it is closed in the stop position it is supposed to ground the coil wire. If it is closed in the reun position then open the splice and connect the ends to the kill switch.
Ron
