Re: Vespa Grande Wiring Diagram
Ron Brown /
Brandon,
Most kill switches just tie the points side of the coil to ground. Look at the coil terminal for extra wires. If you check with a meter, both wires will seem to be ground if the points are closed and the coil is very low resistance too. So disconect the wire at the coil end to check it.
Ron
  Vespa Grande Wiring DiagramTopic by: XBrandon EdgeX XBrandon EdgeX 10/18/01 08:43PM
  Re: Vespa Grande Wiring DiagramRe: miguel miguel 10/18/01 09:34PM
  Re: Vespa Grande Wiring DiagramRe: XBrandon EdgeX XBrandon EdgeX 10/18/01 09:57PM
  Re: Vespa Grande Wiring DiagramRe: miguel miguel 10/19/01 07:28AM
  Re: Vespa Grande Wiring DiagramRe: XBrandon EdgeX XBrandon EdgeX 10/19/01 12:32PM
  Re: Vespa Grande Wiring DiagramRe: don-ohio don-ohio 10/19/01 12:43PM
  Re: Vespa Grande Wiring DiagramRe: DIEGOTREP DIEGOTREP 02/16/10 05:06AM
  Re: Vespa Grande Wiring DiagramRe: Ron Brown Ron Brown 10/19/01 03:30PM
  Re: Vespa Grande Wiring DiagramRe: XBrandon EdgeX XBrandon EdgeX 10/19/01 04:23PM
  Re: Vespa Grande Wiring DiagramRe: Ron Brown Ron Brown 10/19/01 04:58PM
  Re: I got your Wiring Diagram...Re: Jim C. Jim C. 10/19/01 10:20PM
  Re: I got your Wiring Diagram...Re: Jake Van Order Jake Van Order 07/13/04 05:29PM
  Re: I got your Wiring DiagramRe: Jim C. Jim C. 10/19/01 10:27PM
  Re: I got your Wiring DiagramRe: XBrandon EdgeX XBrandon EdgeX 10/20/01 12:05AM
  Re: I got your Wiring DiagramRe: miguel miguel 10/20/01 11:51PM
  Re: I got your Wiring DiagramRe: XBrandon EdgeX XBrandon EdgeX 10/21/01 12:54AM
  Re: I got your Wiring DiagramRe: miguel miguel 10/21/01 01:24AM
  Re: I got your Wiring DiagramRe: Chris S Chris S 10/21/01 09:58AM
  Re: I got your Wiring DiagramRe: miguel miguel 10/21/01 02:41PM
  Re: Sorry for the double post!Re: Jim C. Jim C. 10/19/01 10:42PM
  Re: Sorry for the double post!Re: Jim C. Jim C. 10/19/01 10:43PM
  Re: Fuel FillingRe: Jim C. Jim C. 10/21/01 03:04PM
  Re: Vespa Grande Wiring DiagramRe: Jamesg Jamesg 02/16/10 10:42AM
