Now this is weird...
This has me stumped. Today when checking for a vacume leak, instead of the engine speeding up, it bogged down a bit. I want to know why. Anybody have any ideas?
No mystery here
Ron Brown /
Vespa,
Nice of you to tell us how you were checking for the leak. : )
Assuming you were spraying something on the carb/manifold, either the engine did not like burning what you were spraying or you are running too rich and blocking the extra air made it even richer.
Ron
Re: No mystery here
Sorry ron, didnt know there was thousands of ways to check for a vacume leak. I spayed carb cleaner on the manifold. So what you are saying is that I DO have a leak. Thanks.
Re: No mystery here
There doesn't have to be thousands... there only has to be more than 1
too many of you... leave out too many facts... too often
do you see posts that get NO answers?
thats one of the main reasons why
Re: No mystery here
Jeez guys, I'm sorry I got snappy. I've read tons of older posts, and the only way to check for a vacume leak that I've found mentioned was to spray carb cleaner or wd-40 on the manifold to see if the engine speeds up. That's why I assumed that everyone would know what I was talking about. In the future I will be sure to include as much info as possible about my problems/questions.
And I apologize for my mood, I need to go for a ride and clear my head...I really do appreciate everyone's help, suggestions, and ideas.
Re: No mystery here
Yes... but I think that scenario is wrong.
I'm not sure who said it will "speed up".
Try spraying WD-40 directly into your carburetor while the engine is running fine... I think you will find that it will tend to make your motor slow down or die
What I have usually stated is that ....if you have a CHANGE... in motor speed... then you have an intake leak.
I think I usually stated it as "if your motor speeds up or slows down" you have a leak.
I think people see..."speeds up" and stop reading.
A change in RPM is the clue.
Actually.... I hope somebody reads this today and walks out and tries it and tells us what happens by spraying it directly into the carb.
I think WD40 will kill the motor.
Re: No mystery here
Ron Brown /
Vespa,
I've told you a million times not to exagerate. : )
Btw, thanks Fred, well said.
Another btw, you can spray almost anything to find a leak, and some carb cleaners dont burn too well. Mostly, the liquid will fill small gaps and temporarily seal the leak, making the mixture richer.
Ron
