Re: carburator pics
miguel /
if it's a regular puch carb, there should be a float on it. the manual will have this info it (it should, or else you got ripped off). take the float off.
on a puch carb you just unscrew the bottom of it off. then you'll see a jet in there.
it's a gold screw in the middle. take that out. you can clean it by spraying carb cleaner on it. you should be able to hold it up to a light and see through it.
that tiny hole in the screw comes in different sizes (on different screws). those are the jets. there should be a number marked on it. that's the size of the jet. you can order other ones (bigger or smaller).
go to mopedjunkyard.com ... i think they have bing carburetor explosions that you can use to see things on. follow this link:
<a href=http://www.mopedjunkyard.com/bingpuch.html>http://www.mopedjunkyard.com/bingpuch.html</a>;
the part #21 is the bottom of the carb. unscrew that. part#1 is the jet.
  carburator picsTopic by: clay clay 10/14/01 05:34AM
  Re: carburator picsRe: don-ohio don-ohio 10/14/01 06:09AM
  Re: carburator picsRe: Matt Matt 10/14/01 11:31AM
  Re: carburator picsRe: Claude Bawls Claude Bawls 10/14/01 03:10PM
  Re: carburator picsRe: Chris Chris 10/14/01 03:17PM
  Re: carburator picsRe: miguel miguel 10/15/01 02:49AM
  Re: carburator picsRe: Clay Clay 10/16/01 12:10AM
  Re: carburator picsRe: Ron Brown Ron Brown 10/16/01 12:22AM
  Re: carburator picsRe: miguel miguel 10/16/01 12:32AM
