Re: carburator pics
Chris /
What are the numbers on the side of the carb? How many carbs do you need ? $140 should get you 2 carbs. Don't be confused by shops that sell the "puch maxi carb" Bing carb number 1/15/46a . That specific carburetor never came on any puch moped. It is however an acceptable replacement carburetor but it will also require rejetting and possible nozzle/low speed mixture needle replacement. Most good shops will sell it for about $65.00 and they will exchange the jet for any available size you wnat for ne additional charge.
BTW On all bing carburetors ( Puch, Sachs, Kriedler, batavus, tomos(encarwi))the first of number is the modle series number (The physical dimmensions and make up ), the second set of numbes is the venturi size, and the last set of numbers identifies the Jet,nozzle,low speed mixture needle, and throttle slide variations.
Chris
  carburator picsTopic by: clay clay 10/14/01 05:34AM
  Re: carburator picsRe: don-ohio don-ohio 10/14/01 06:09AM
  Re: carburator picsRe: Matt Matt 10/14/01 11:31AM
  Re: carburator picsRe: Claude Bawls Claude Bawls 10/14/01 03:10PM
  Re: carburator picsRe: Chris Chris 10/14/01 03:17PM
  Re: carburator picsRe: miguel miguel 10/15/01 02:49AM
  Re: carburator picsRe: Clay Clay 10/16/01 12:10AM
  Re: carburator picsRe: Ron Brown Ron Brown 10/16/01 12:22AM
  Re: carburator picsRe: miguel miguel 10/16/01 12:32AM
