Re: 1977 puch maxi
Brian /
Are you sure it's not the engine ? If it is indeed the tranny, the first thing I'd do is check the starting lever for proper adjustment, drain the ATF out and check it for metal, then refill it to the correct level using "F type" ATF and try running it again. It could be clutch plates sticking, if it still knocks then it'll have to be opened up for a closer examination.
  1977 puch maxiTopic by: david david 10/12/01 01:57PM
  Re: 1977 puch maxiRe: Brian Brian 10/12/01 02:22PM
  Re: 1977 puch maxiRe: david david 10/12/01 04:14PM
  Re: 1977 puch maxiRe: Zippy Zippy 10/12/01 06:01PM
  Re: 1977 puch maxiRe: Ron Brown Ron Brown 10/12/01 07:05PM
