Building a Motobecane manual V1.0
Hey Everybody, I got tired of answering alot of questions about motobecane timing, so I started putting together an article. I would like to get some feedback/input/edits before I submit it to be posted in the articles section. If anybody wants to add anything, or write a little peice about motobecane repair, or performance tuning that would be great
pic 1
Pics 1
Pic 2
Pic 2
Re: Building a Motobecane manual V1.0
Ben Van Zoest /
Great job, nice explanations.
I know there are some motobecaners out there who know more than me.
got any performance hints?
Felipe Fernandez /
Hello,
I will try this on my motobecane that is currently not working. I'll let you know my results as soon as possible. In any case, I will post on the repair section the main issues I have with it if anyone can help, I'm not sure yet that is timing that it needs, but i think it should be checked properly in anycase.
Thanks a lot!
Felipe
The best performance hint for Motobecane owners is to get a 70 cc kit. I have them listed on my site.
Chris MWH
www.mopedwarehouse.com
www.mopedguru.com
Bill Mullins /
thanks Dan your guide is a great help i will let you know how iget on thanks again
where could i find the cam puller i need to do this???
Edward Cohen /
is there a specific 70cc i need my motobecane.... and im not that handy... Is it very difficult to install?
Mopedwarehouse had a 70cc airsal kit for motobecane.
I don't know if it is any good
how many cc is the mobylette???
i have no manual so i dont know. i have 3 motori marini piston kits here and i would use them if they are the right size
the box says they are 40 mm. is that what i need.
(i dont know that i need to install one but to know that i had the one i needed would be nice)
also is there anything else i could use instead of a cam puller.
ill buy the tool but im just curious
49cc
here is the motobecane shop manual.
Contains much usefull info.
http://mopedriders.org/article_view.php?faq=2&fldAuto=18
moped_bandit,
There is no safe way to pull the point cam or flywheel without the special tool.
Mopedwarehouse.com has the tools, and they are reasonable (~$20)
ok ill get it then
thanx
Slightly updated version
I made some updates to this a while ago, and never relisted.
2nd try
OK i added the extension this time
MOTOB MANUAL 1.2
Please work this time
(Shrug)
save as...
Add the extension .doc
then open with word
Re: (Shrug)
thanks for the great info.
i have a question about multimeters: how do you use a multimeter? you say to set it to continuity, but i have this dial with symbols that i am not familiar with. thanks :)
