Re: t-t-t-t-timing
don-ohio /
Good info. Ron! Also,I would say for anybody to use a timing light to set the final time AFTER ascertaining that the timing marks are CORRECT.Which they were 20 degrees OFF on my Franco-Morini the other day.If your timing marks are off as mine were,you will have to find TDC and measure accordingly or mark the magneto-flywheel at EXACTLY the distance listed in your manual before piston hits TDC.If I hadn't found Franco-Morini's mistake I'd have been timed 20 degrees slow forever.I NOW check the marks every time before hooking up the timing light.
  What to do?Topic by: tabpat tabpat 10/10/01 11:18PM
  Re: What to do?Re: Steeltoad Steeltoad 10/10/01 11:47PM
  Still too richRe: Fred Fred 10/10/01 11:49PM
  Re: Still too richRe: tabpat tabpat 10/11/01 12:14AM
  They all skip numbers.Re: Fred Fred 10/11/01 12:26AM
  Re: They all skip numbers.Re: tabpat tabpat 10/11/01 12:40AM
  Re: They all skip numbers.Re: Fred Fred 10/11/01 04:48PM
  Re: What to do?Re: tabpat tabpat 10/11/01 09:45PM
  Re: What to do?Re: Rog Rog 10/11/01 10:03PM
  Re: What to do?Re: tabpat tabpat 10/11/01 11:00PM
  Re: What to do?Re: don-ohio don-ohio 10/12/01 03:27AM
  Re: What to do?Re: Tabpat Tabpat 10/12/01 08:25AM
  t-t-t-t-timingRe: tabpat tabpat 10/12/01 10:27AM
  Re: t-t-t-t-timingRe: mbartell mbartell 10/12/01 11:10AM
  Re: t-t-t-t-timingRe: Ron Brown Ron Brown 10/12/01 11:38AM
  Re: t-t-t-t-timingRe: don-ohio don-ohio 10/12/01 09:48PM
