Re: t-t-t-t-timing
mbartell /
Just trying to think logically here, but the longer the points are open (larger gap) the smaller the charge in the coil. So the points can control the power of the spark. The strator plates would control when, according to where the crank is, the plug sparks. This should be a specific measurement before top dead center.
Depending on how the points gap is set, it can cause the spark later, and the strator plates should be advanced to keep the spark at the correct timing with relation to the crank poosition, if you want to stay with factory specs.
Is this right, or should I get more coffee?
  What to do?Topic by: tabpat tabpat 10/10/01 11:18PM
  Re: What to do?Re: Steeltoad Steeltoad 10/10/01 11:47PM
  Still too richRe: Fred Fred 10/10/01 11:49PM
  Re: Still too richRe: tabpat tabpat 10/11/01 12:14AM
  They all skip numbers.Re: Fred Fred 10/11/01 12:26AM
  Re: They all skip numbers.Re: tabpat tabpat 10/11/01 12:40AM
  Re: They all skip numbers.Re: Fred Fred 10/11/01 04:48PM
  Re: What to do?Re: tabpat tabpat 10/11/01 09:45PM
  Re: What to do?Re: Rog Rog 10/11/01 10:03PM
  Re: What to do?Re: tabpat tabpat 10/11/01 11:00PM
  Re: What to do?Re: don-ohio don-ohio 10/12/01 03:27AM
  Re: What to do?Re: Tabpat Tabpat 10/12/01 08:25AM
  t-t-t-t-timingRe: tabpat tabpat 10/12/01 10:27AM
  Re: t-t-t-t-timingRe: mbartell mbartell 10/12/01 11:10AM
  Re: t-t-t-t-timingRe: Ron Brown Ron Brown 10/12/01 11:38AM
  Re: t-t-t-t-timingRe: don-ohio don-ohio 10/12/01 09:48PM
