Still too rich
Fred /
You are making an assumption that it is now lean because it bogs a little at full throttle with a 58 at 34mph when it used to 4 stroke and only go 30mph with a 60 ??
And it will go a little faster when you back off the throttle ?
Then you are still too rich.
You are not "in between".
There is no way a 60 would cause 4 stroking... and then a 58 would be too lean.
Buy a 56 and try it... (it'll get faster yet)... then do a plug chop and evaluate the plug color.
You should do a plug chop with the 58 first... also.
Then switch to the 56 and test and check.
ALWAYS do a plug chop when trying different main jets.
And........ All this info is already in the "How to fix your Moped" guide.
  What to do?Topic by: tabpat tabpat 10/10/01 11:18PM
  Re: What to do?Re: Steeltoad Steeltoad 10/10/01 11:47PM
  Still too richRe: Fred Fred 10/10/01 11:49PM
  Re: Still too richRe: tabpat tabpat 10/11/01 12:14AM
  They all skip numbers.Re: Fred Fred 10/11/01 12:26AM
  Re: They all skip numbers.Re: tabpat tabpat 10/11/01 12:40AM
  Re: They all skip numbers.Re: Fred Fred 10/11/01 04:48PM
  Re: What to do?Re: tabpat tabpat 10/11/01 09:45PM
  Re: What to do?Re: Rog Rog 10/11/01 10:03PM
  Re: What to do?Re: tabpat tabpat 10/11/01 11:00PM
  Re: What to do?Re: don-ohio don-ohio 10/12/01 03:27AM
  Re: What to do?Re: Tabpat Tabpat 10/12/01 08:25AM
  t-t-t-t-timingRe: tabpat tabpat 10/12/01 10:27AM
  Re: t-t-t-t-timingRe: mbartell mbartell 10/12/01 11:10AM
  Re: t-t-t-t-timingRe: Ron Brown Ron Brown 10/12/01 11:38AM
  Re: t-t-t-t-timingRe: don-ohio don-ohio 10/12/01 09:48PM
