What to do?
tabpat /
Need some advice... (Puch Magnum MKII)
What do you do when you need a jet that is "in between" sizes? My stock jet is a #60. It will do 30mph and then "4-stroke." If I put a #58 jet in, I can hit 34, but you can tell it is running lean as there is a slight bog at full throttle. There was a small hole drilled in the air cleaner and I imagine it was done at the factory. I plugged it, and the speed dropped to 25mph with the stock 60 jet. I re-opened it and drilled another small hole right next to it. The speed is back to 30.
The guys at the moped warehouse correctly diagnosed another problem...
I have a replacement Bing 15mm carb on it. They said the nozzle and needle are different on those carbs and I need to run it with the stock parts. <very smart, those guys at the warehouse> I did that, then experimented a little. If I run the stock nozzle with the new needle, it will lean out slightly right before full throttle. I am running it this way as I can run up to 30 with it "floored" then back it off just a bit to hit 34. Is this a logical fix for an in-between jet?
  What to do?Topic by: tabpat tabpat 10/10/01 11:18PM
  Re: What to do?Re: Steeltoad Steeltoad 10/10/01 11:47PM
  Still too richRe: Fred Fred 10/10/01 11:49PM
  Re: Still too richRe: tabpat tabpat 10/11/01 12:14AM
  They all skip numbers.Re: Fred Fred 10/11/01 12:26AM
  Re: They all skip numbers.Re: tabpat tabpat 10/11/01 12:40AM
  Re: They all skip numbers.Re: Fred Fred 10/11/01 04:48PM
  Re: What to do?Re: tabpat tabpat 10/11/01 09:45PM
  Re: What to do?Re: Rog Rog 10/11/01 10:03PM
  Re: What to do?Re: tabpat tabpat 10/11/01 11:00PM
  Re: What to do?Re: don-ohio don-ohio 10/12/01 03:27AM
  Re: What to do?Re: Tabpat Tabpat 10/12/01 08:25AM
  t-t-t-t-timingRe: tabpat tabpat 10/12/01 10:27AM
  Re: t-t-t-t-timingRe: mbartell mbartell 10/12/01 11:10AM
  Re: t-t-t-t-timingRe: Ron Brown Ron Brown 10/12/01 11:38AM
  Re: t-t-t-t-timingRe: don-ohio don-ohio 10/12/01 09:48PM
