Re: There is a way
Nick /
I think it'll be a little more complicated than that but thanks for the input. Here's why...
Yellow (Yellow black out of switch) feeds the headlite and speedo lite
Green (Blue/Green out of switch) feeds the brake lite
Grey feeds the tail lite
Grey is the one that puzzles me. There must be a voltage sensor on Yellow (to headlite) in the stator that activates grey (to tail lite) when the headlite is turned on.
So, I'll have to move the Grey feed and connect it in with the headlite switch for this to work.
I think another way is to run two small 6V batteries (which I have :) ) Both are 4.5 amp.
At the connecting block.....
Yellow to + on Battery 1 (with diode of course)
Ground the - of Battery 1 to a brown or chassis
Disconnect grey at block and extend it (the tail lite end) to connect to Yellow/Black either at speedo or headlite
....this will cover the headlite/speedo/tail lite
Drain will be ~36 watts here
Green to + on Battery 2 (diode)
Ground the -
...this will cover the brake lites
Drain is 10 watts when used.
Like I ever do much riding at nite but I'd like to figure this out. Anyone know the exact Voltage/Current outputs on these feeds?
Nick
  Battery on PuchTopic by: Nick Nick 10/06/01 09:04AM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 12:54PM
  Re: Battery on PuchRe: Nick Nick 10/06/01 01:44PM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 02:27PM
  Re: Battery on PuchRe: Nick Nick 10/06/01 02:52PM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 03:52PM
  Re: Battery on PuchRe: oldtimer oldtimer 10/06/01 05:34PM
  Re: I'll bring the marshmallowsRe: Jim C. Jim C. 10/07/01 12:22AM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/07/01 05:46PM
  Re: I'll bring the marshmallowsRe: oldtimer oldtimer 10/07/01 06:30PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/07/01 11:27PM
  Re: I'll bring the marshmallowsRe: Ron Brown Ron Brown 10/08/01 11:34AM
  Re: I'll bring the marshmallowsRe: Roberto Roberto 10/08/01 02:11PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:26PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:33PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:15PM
  Re: I'll bring the marshmallowsRe: Ron Brown Ron Brown 10/09/01 12:48PM
  Re: There is a wayRe: oldtimer oldtimer 10/09/01 06:49PM
  Re: There is a wayRe: Nick Nick 10/09/01 09:39PM
  Re: There is a wayRe: Brandon Brandon 07/11/06 04:41PM
  Re: There is a wayRe: brystheguy brystheguy 07/11/06 04:47PM
  Re: There is a wayRe: Chris Chris 07/14/06 01:23AM
  Re: There is a wayRe: Chris Chris 07/14/06 01:25AM
  Re: There is a wayRe: Daniel Daniel 07/14/06 01:35AM
