Re: I'll bring the marshmallows
Nick /
In a way you are correct. I am not going to debate (much) exactly what the power source is out of the magnetos in the stator/flywheel but......
To be AC you have to have a return and that is not present. IE: The neutral wire in your house wiring.
The Puch has a "pulsed" voltage source of + 6V and chassis ground. That's it. And Puch 7-wire "may" have 4 sources which will mean I have two that are 180 degrees out of phase so I should be able to rectify and produce DC. After cleaning it up with a good capacitor that is.
So, if I leave the coil feed alone and only mess with the lights I should be able to do this but we'll see. hmmm....6v one side, 6v the other. With some capacitors and a voltage regulator I could convert to 12v for the lights if the output is enough to produce a charge.
Nick
  Battery on PuchTopic by: Nick Nick 10/06/01 09:04AM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 12:54PM
  Re: Battery on PuchRe: Nick Nick 10/06/01 01:44PM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 02:27PM
  Re: Battery on PuchRe: Nick Nick 10/06/01 02:52PM
  Re: Battery on PuchRe: InfectedBootSector InfectedBootSector 10/06/01 03:52PM
  Re: Battery on PuchRe: oldtimer oldtimer 10/06/01 05:34PM
  Re: I'll bring the marshmallowsRe: Jim C. Jim C. 10/07/01 12:22AM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/07/01 05:46PM
  Re: I'll bring the marshmallowsRe: oldtimer oldtimer 10/07/01 06:30PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/07/01 11:27PM
  Re: I'll bring the marshmallowsRe: Ron Brown Ron Brown 10/08/01 11:34AM
  Re: I'll bring the marshmallowsRe: Roberto Roberto 10/08/01 02:11PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:26PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:33PM
  Re: I'll bring the marshmallowsRe: Nick Nick 10/08/01 08:15PM
  Re: I'll bring the marshmallowsRe: Ron Brown Ron Brown 10/09/01 12:48PM
  Re: There is a wayRe: oldtimer oldtimer 10/09/01 06:49PM
  Re: There is a wayRe: Nick Nick 10/09/01 09:39PM
  Re: There is a wayRe: Brandon Brandon 07/11/06 04:41PM
  Re: There is a wayRe: brystheguy brystheguy 07/11/06 04:47PM
  Re: There is a wayRe: Chris Chris 07/14/06 01:23AM
  Re: There is a wayRe: Chris Chris 07/14/06 01:25AM
  Re: There is a wayRe: Daniel Daniel 07/14/06 01:35AM
